ERROR
Invalid username or password
Last Published: January 11, 2023
Error Message
When attempting to configure Portal for ArcGIS to use ArcGIS Online utility services, the following error message is returned:
Error:
Invalid username or password.
Configuring ArcGIS Online utility services in Portal for ArcGIS fails with an error message.
Cause
An incorrect letter case is used in the login credentials.
Solution or Workaround
Portal for ArcGIS is case sensitive when accepting credentials from ArcGIS Online. Resolve this issue by using the correct case for the username as in ArcGIS Online.
Article ID: 000029012
Software:
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
