ERROR
Attempting to connect to an enterprise geodatabase or SQL database failed and the following error is returned:
Error: The ArcGIS Server license is missing or not valid. Please provide the path to an authorization file (ECP file) that contains an ArcGIS Server License.
The keycodes file used as the Authorization File parameter in the Create Enterprise Geodatabase tool to create the connection to the database in ArcGIS Pro is expired. The default folder location for the keycodes file is as follows:
C:\Program Files\ESRI\License10.x\sysgen
The following image shows a sample of a keycodes file with the expiry date:
Replace the expired ArcGIS Enterprise and enterprise geodatabase licenses with a new license containing the new expiry date. Refer to How To: Replace expired ArcGIS Server and enterprise geodatabase licenses for instructions.
Article ID: 000027828
Get help from ArcGIS experts
Start chatting now
