ERROR
Packaging succeeded, but publishing failed. ERROR 160235: There is not enough storage space to complete the operation
First Published: January 20, 2023
Last Published: January 20, 2023
Error Message
Attempts to publish a feature service or a web layer from ArcGIS Pro or ArcMap to ArcGIS Server fail with the following error message returned:
Error:
ERROR 160235: There is not enough storage space to complete the operation.
Please consult the GP Results Window for enhanced error description or contact your administrator for the server logs.
The error message returned when attempting to publish a feature service or web layer to ArcGIS Server
Cause
The PublishingTools service and the PublishingTools10x service has stopped or is unresponsive in ArcGIS Server.
Solution or Workaround
  1. Log in to ArcGIS Server Manager as an adminstrator. The URL format is:
https://gisserver.domain.com:6443/arcgis/manager
https://gisserver.domain.com/webadaptorname/manager
  1. On the ArcGIS Server Manager home page, navigate to Manage Services > System.
  2. Ensure the PublishingTools service is running.
  • If the service is stopped, click Start Start the service to start the service.
  • If the service is still running, click Stop Stop the service and Start Start the service to restart the service.
  1. Log in to ArcGIS Server Administrator as an administrator. The URL format is:
https://gisserver.domain.com:6443/arcgis/admin
https://gisserver.domain.com/webadaptorname/admin
  1. Under Resources, click services.
  2. Under Folders, click System.
  3. Under Services, click the PublishingTools10x service.
  4. Under Supported Operations, click stop.
  5. On the Stop Service page, click Stop.
The option to stop the PublishingTools10x service
  1. On the Service - PublishingTools10x page, click start under Supported Operations.
  2. On the Start Service page, click Start.
The option to start the PublishingTools10x service
Article ID: 000029300
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
