ERROR
"Not_Set" is an invalid hostname. Please enter a valid hostname
First Published: December 20, 2018
Last Published: July 21, 2025
Error Message
When attempting to launch ArcMap, the following error message is returned:
Error:
"Not_Set" is an invalid hostname. Please enter a valid hostname.
Image of the error message
Cause
The error occurs when a 'Concurrent Use' license level is selected in ArcGIS Administrator, and no License Manager is defined.
Image of the ArcGIS Administrator window showing no License Manager is defined
Solution or Workaround
To circumvent the issue, follow the steps below:
  1. Launch ArcGIS Administrator.
  2. Ensure the correct license level is selected.
  3. If a Concurrent Use license level is selected, click 'Change...' to define a License Manager.
  1. Enter the name of the License Manager in the available field. Alternatively, click 'Browse...' to connect to a specific computer on the network. Click OK.
  1. Click Apply, and OK.
  2. Close ArcGIS Administrator, and relaunch ArcMap.
Article ID: 000019515
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
