ERROR
Invalid Portal credentials. Please check username and password and try again
Last Published: April 27, 2022
Error Message
In some instances, attempts to configure the ArcGIS Survey123 website in an ArcGIS Enterprise deployment after the installation completes fail, and return the following error message:
Error:
Error showing the 'Invalid Portal credentials. Please check username and password and try again' message
Cause
  • The login credentials of the Portal for ArcGIS user account are incorrect.
  • The URL of Portal for ArcGIS used in the post installation configuration is incorrect.
Solution or Workaround
Choose one of the methods below, depending on the cause, to resolve the issue.
Use a valid username and password
Use a valid username and password for Portal for ArcGIS.
Check the credentials for case sensitivity. Refer to Portal for ArcGIS: Password policy for more information.
Use the correct URL for Portal for ArcGIS
Use the correct URL for Portal for ArcGIS in the post installation configuration. Refer to Portal for ArcGIS: Components of ArcGIS URLs for more information.
Article ID: 000025215
Software:
  • Portal for ArcGIS
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
