ERROR
Attempts to register a feature dataset as versioned returns an error message:
Error: Failed to register as versioned. Operation is not supported on a table that is moving edits to base.
This issue occurs when a feature dataset contains feature classes that have different settings selected when registering as versioned. During the process to register a feature class as versioned, the option to move edits to base is available. In the event the feature dataset contains one or more feature classes that are registered with the move edits to base options selected (while the remaining feature classes do not) the error message is returned.
For more information on the option to move edits to base, please refer to ArcGIS Help: Deciding how to register data.
Use one of the two workaround options listed below to solve this issue.
Warning: The following workarounds may affect users and map services connected to the geodatabase. It is recommended to disconnect all users and shut down all map services connected to the geodatabase before attempting the following workarounds.
Dependent dataset
This workaround retains all data within the dataset. If the affected feature classes or annotation classes are not critical or in use, please refer to Non-dependent dataset.
This solution removes the feature classes or annotation classes that have the move edits to base options selected.
Article ID:000012902
Get help from ArcGIS experts
Download the Esri Support App
