ERROR
In ArcGIS Online, when attempting to update a member’s role to a default Viewer, Data Editor, or custom role, the following error message is returned.
Error: Error updating role for the selected member.
This issue occurs when the member does not have the ‘Create, update, and delete’ privilege and is a group member of a shared update group. A member of a shared update group without the ‘Create, update, and delete’ privilege cannot be assigned a default Viewer, Data Editor, or custom role.
Use one of the methods below to resolve the issue.
Note: Only organization administrators can perform the workflows.
Assign the required privilege to the member in the shared update group
For the member to remain in the shared update group, enable the Create, update, and delete option in the General privileges settings of the custom role, and assign it to the member. Refer to ArcGIS Online: Configure member roles for more information.
Remove the member from the shared update group
To assign a default Viewer, Data Editor, or custom role without the Create, update, and delete privilege to a member, click Remove member from group to remove the member from the shared update group. Refer to ArcGIS Online: Manage groups for a specific member for more information.
Assign a default role to the member
Change the member’s role to a default role such as User, Publisher, or Administrator. Refer to ArcGIS Online: Change member roles for more information.
Article ID:000025589
Get help from ArcGIS experts
Download the Esri Support App
