ERROR
ERROR: code:500, Service Hosted/<map service name>/MapServer not found , Internal server error
Last Published: September 23, 2021
Error Message
Attempting to publish a web map with copied data from ArcGIS Pro to Portal for ArcGIS fails, and the following error message is returned:
Error:
ERROR: code:500, Service Hosted/<map service name>/MapServer not found , Internal server error.
Cause
The following are possible causes:
  • ArcGIS Data Store is not validated with ArcGIS Server.
  • The relational data store is in read-only mode. This happens when the available disk space is less than 1024 MB.
Solution or Workaround
Use any of the following solutions depending on the cause:
Validate ArcGIS Data Store
Refer to How To: Validate ArcGIS Data Store for steps to do this.
Set ArcGIS Data Store to read-write mode
  1. Increase the disk space of the ArcGIS Data Store machine. Refer to ArcGIS Enterprise: Disk space requirements for more information.
  2. Change the relational data store from read-only to read-write mode. Refer to the solution section of this article, Error: Failed to create new feature(s). General Function Failure [database error has occured.] for more information.
Article ID: 000025278
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
