ERROR
ArcGIS Pro: ERROR 999999 Something unexpected caused the tool to fail with utility networks
Error Message
When working with utility networks in ArcGIS Pro, attempting to run the Add Rule or Import Rule geoprocessing tool may return the following error message:
Error:
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (https://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Unexpected operation [Error updating row from table ..UN_6_Props]
Failed to execute (AddRule)
Cause
This error is displayed when the existing enterprise geodatabase connection in the ArcGIS Pro project has the versioning type set to Traditional instead of Branch in the Geodatabase Connection Properties window.
Solution or Workaround
Set the enterprise geodatabase connection to the Branch versioning type in Geodatabase Connection Properties.
  1. In the Catalog pane in ArcGIS Pro, right-click the enterprise geodatabase connection, and click Geodatabase Connection Properties.
The enterprise geodatabase options
  1. In the Geodatabase Connection Properties window, under Versioning Type, select Branch.
The Geodatabase Connection Properties window
  1. Run the Add Rule or Import Rule geoprocessing tool.
Article ID: 000023667
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
