ERROR
A previous uninstall has not completed; the machine must be restarted. After restarting, files may remain on disk that will conflict with the installation
First Published: January 25, 2018
Error Message
When upgrading from ArcGIS 10.5 and 10.5.1 to ArcGIS Enterprise 10.6 GeoAnalytics Server, the following error message is returned:
Error:
A previous uninstall has not completed; the machine must be restarted. After restarting, files may remain on disk that will conflict with the installation. Please rename the folder <ArcGIS GeoAnalytics Server install location>\ArcGIS\Server\ before running the ArcGIS Server 10.6 setup again.
Cause
During an upgrade from ArcGIS GeoAnalytics Server 10.5 or 10.5.1 to 10.6, there is a known issue caused by detached ArcGIS Server processes which may impede the upgrade process. When these ArcGIS Server processes are still running during an ArcGIS GeoAnalytics Server upgrade, the upgrade may be impeded and server settings may be lost.
Solution or Workaround
If prompted by this error message, rename the folder, restart the machine, and rerun the Server 10.6 setup.exe file. Any preset server settings will be lost.
It is advised to follow the best practices laid out in How to: Upgrade an ArcGIS GeoAnalytics Server site to avoid this error and successfully upgrade ArcGIS GeoAnalytics Server to 10.6.
Prior to upgrading, complete the steps described in ArcGIS Server: Back up and restore your ArcGIS Server site configuration and roll back the ArcGIS GeoAnalytics Server site to its backup configuration. After this, follow the steps outlined in the ArcGIS Server help section articles ArcGIS Enterprise: Upgrade using the setup program (For Windows) ArcGIS Enterprise: Upgrade ArcGIS Server on Linux to upgrade the server(s) to ArcGIS GeoAnalytics Server 10.6 without error.
Article ID: 000017514
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
