ERROR
Could not connect to an ArcGIS license manager running on host "Not_Set"
Last Published: July 18, 2025
Error Message
When launching ArcMap, the following error returns:
Error:
Cause
This error occurs if a license is not authorized or when the location of the ArcGIS License Manager is not specified after authorizing ArcMap with a Concurrent Use license.
Solution or Workaround
Authorize ArcMap with a Single Use license
ArcMap is authorized with either a Concurrent Use or Single Use license. Single Use license authorization is performed on the machine where ArcMap is installed and requires an authorization code from MyEsri. Refer to ArcMap: Authorizing your software for more information on authorizing ArcMap for single use.
Administrator rights on the machine are required to select a Single Use license in ArcGIS Administrator. In Windows, right-click ArcGIS Administrator, and click Run as administrator.
Set the license manager location
If the error occurs when using a Concurrent Use license, set the location of the license manager in ArcGIS Administrator. Refer to Error: "Not_Set" is an invalid hostname. Please enter a valid hostname. for more information.
Article ID: 000019941
Software:
  • ArcMap 10 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
