ERROR
ArcGIS Server: Systems operational, some issues
Last Published: November 12, 2025
Error Message
When attempting to validate a hosting server in ArcGIS Server, the following error is returned:
Error: Systems operational, some issues
Cause
  • ArcGIS Server does not have ArcGIS Web Adaptor configured.
  • The ArcGIS Enterprise portal contains the incorrect ArcGIS Web Adaptor URL.
  • Windows Authentication is enabled and Anonymous Authentication is disabled as the authentication method for the web adaptor of the federated ArcGIS Server.
Solution or Workaround
Configure ArcGIS Web Adaptor
Configure ArcGIS Web Adaptor with ArcGIS Server to route web requests through Internet Information Services (IIS) Manager and allow the portal to communicate securely with the hosting server. Refer to ArcGIS Enterprise: Configure ArcGIS Web Adaptor with a server site for instructions.
Update the ArcGIS Web Adaptor URL in the ArcGIS Enterprise portal
Update the ArcGIS Web Adaptor URL in the portal so it references the correct endpoint of the hosting server. This step is necessary after reconfiguring or reinstalling the ArcGIS Web Adaptor. Refer to ArcGIS Enterprise: Configure ArcGIS Web Adaptor with Portal for ArcGIS for instructions.
Modify the authentication method settings for the web adaptor
Enable Anonymous Authentication and disable Windows Authentication for the authentication method settings for the web adaptor using Internet Information Services (IIS) Manager. Refer to Steps 1 through 5 in Error: ArcGIS Server services URL '<https://server.domain.com/webadaptor>' cannot be validated against '<https://server.domain.com/webadaptor/rest/info>' for instructions and more information.
Article ID: 000038528
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise
  • ArcGIS Web Adaptor
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
