ERROR
ArcGIS Server: Consolidation failed
First Published: August 17, 2022
Last Published: April 19, 2024
Error Message
When attempting to publish a map as a map service from ArcGIS Pro to ArcGIS Server, the following error is returned in the ArcGIS Server logs:
Error:
Cause
The data source of one or more layers in the map are moved or renamed, causing the connection to the layer to be broken with no data to display. Additionally, in some cases, the red exclamation point is not displayed next to the layer in the Contents pane in ArcGIS Pro, making it difficult to identify the layers with broken data sources.
Solution or Workaround
In ArcGIS Pro, identify the layers with the incorrect data source and ensure the layers are set with the correct data source. Complete the workaround below to specify the layer with the correct data source.
  1. Open the ArcGIS Pro project.
  2. In the Contents pane, right-click the layer and click Properties.
  3. In the Layer Properties dialog box, click Source.
  4. Click Set Data Source….
The layer configuration in the Layer Properties dialog box.
  1. In the Change data source dialog box, specify the correct data source of the layer.
  2. Click OK > OK. Publish the map as a map service to ArcGIS Server.
Article ID: 000027986
Software:
  • ArcGIS Pro
  • ArcGIS Server
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
