ERROR
ArcGIS Server: Connection property set missing required property or property value unrecognized. Invalid connection property
Last Published: April 16, 2025
Error Message
Validating the relational data store using JSON in the ArcGIS Server Administrator Directory fails and returns the following error message:
Error:
The connection property set was missing a required property or the property value was unrecognized. Invalid connection property.[]
Additionally, attempts to validate the relational data store via ArcGIS Server Manager fail without returning an error message.
Cause
Port 9876 (TCP) is closed, preventing proper communication with the relational data store.
Solution or Workaround
Enable port 9876 (TCP). Refer to ArcGIS Enterprise: Ports used by ArcGIS Data Store for additional information.
Contact the organization's IT personnel to enable port 9876 (TCP).
Article ID: 000034858
Software:
  • ArcGIS Data Store
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
