ERROR
ArcGIS Pro: This geodatabase does not support this client or operation. Failed to execute
Last Published: November 15, 2024
Error Message
When attempting to create tables with a Structured Query Language (SQL) client and registering the tables with an enterprise geodatabase in ArcGIS Pro, the process fails and returns the following error:
Error:
Failed to execute (RegisterWithGeodatabase).
The geodatabase not supported error message
Cause
The enterprise geodatabase does not support the new data types introduced in ArcGIS Pro 3.2. These new data types include:
  • Big integer
  • Date only
  • Time only
  • Timestamp offset
These data types are only supported in enterprise geodatabase versions 11.2 and later. When a table created using a SQL client includes any of these new data types and the geodatabase is not in the required version, the registration process fails.
Solution or Workaround
Upgrade the enterprise geodatabase
Perform an upgrade on the enterprise geodatabase to match the current version of ArcGIS Pro installed on the machine. Refer to ArcGIS Pro: Upgrade Geodatabase (Data Management) for additional information.
Register the enterprise geodatabase with ArcGIS Pro 3.1
  1. Perform a clean uninstallation of ArcGIS Pro. Refer to Steps 1 through 6 of How To: Perform a clean uninstall and reinstall of ArcGIS Pro for instructions.
  2. Download ArcGIS Pro 3.1 from My Esri or ArcGIS Online. Refer to ArcGIS Pro: Download ArcGIS Pro for instructions.
  3. Install ArcGIS Pro 3.1 on the machine. Refer to ArcGIS Pro: Install ArcGIS Pro for instructions.
  4. Register the tables with an enterprise geodatabase. Refer to ArcGIS Pro: Register with the geodatabase for instructions.
Article ID: 000033007
Software:
  • ArcGIS Server
  • ArcGIS Pro 3 1
  • ArcGIS Enterprise 11 1
  • ArcGIS Pro 3 3
  • ArcGIS Enterprise 11 3
  • ArcGIS Enterprise 11 2
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
