ERROR
In ArcGIS Pro, using a simple feature layer as input for the Export 3D Objects tool returns the following error message:
Error: Error 003767 The input feature class is not 3D Object. Upgrade to 3D Object with the "Add 3D Formats To Multipatch (Data Management)" tool.
This is expected behavior. The Export 3D Objects tool does not support simple feature layer types, such as polygon, point, line, or multipatch, as input. Only 3D object feature layers are supported as input.
Note: Skip Step 3 if the feature layer is a multipatch.
Note: The Layer 3D To Feature Class tool requires the input feature layer to have 3D display properties defined. If necessary, set the feature layer extrusion type to define its 3D display properties in the local scene view. Refer to ArcGIS Pro: Extrude features for more information.
Note: The Add 3D Formats To Multipatch tool requires an ArcGIS Pro Standard or Advanced license.
Article ID: 000034907
Get help from ArcGIS experts
Start chatting now
