ERROR
After upgrading ArcGIS Pro, the following error is returned when opening ArcGIS Notebooks:
Error:
Notebook not found at the requested URL. This may be caused by an unsupported proxy configuration, or an invalid Jupyter Notebook server configuration.
The following are possible causes for the error message:
Depending on the cause, use one of the workarounds below to resolve the issue:
c.NotebookApp.ip = '0.0.0.0'
c.NotebookApp.port = 8888
If the Python environment is corrupted, repair or upgrade it through ArcGIS Pro’s built-in tools to restore missing or damaged files and ensure compatibility. Refer to ArcGIS Pro: Repair an environment for instructions.
An exclusion must be set by the IT department on the proxy settings to prevent localhost:8778 or 127.0.0.1:8778 from being routed through the proxy.
Note: If the above workarounds does not resolve the error, uninstall and reinstall ArcGIS Pro. Refer to ArcGIS Pro: Install ArcGIS Pro for instructions.
Article ID: 000034304
Get help from ArcGIS experts
Start chatting now
