HOW TO
Change the default start directory for Jupyter Notebook
First Published: July 31, 2018
Last Published: July 21, 2023
Summary
By default, the start directory for Jupyter Notebook used in ArcGIS API for Python is set to the following folder:
C:\Users\<User>
However, it is possible to start the Jupyter Notebook with a different directory through the Python Command Prompt or by modifying the Jupyter Notebook .py configuration file.
Procedure
Use one of the solutions provided to start Jupyter Notebook in a different directory.
Temporarily start Jupyter Notebook in a different directory using the Python Command Prompt
  1. Start the Python Command Prompt. Click Start > ArcGIS > Python Command Prompt.
  2. Run the following command. The command opens Jupyter Notebook with the defined directory.
jupyter notebook --notebook-dir [LOCATION]
The Python Command Prompt with the command to start the Notebook in a different directory
Change the default directory by generating a config file
  1. Start the Python Command Prompt by clicking Start > ArcGIS > Python Command Prompt.
  2. Type the command below to create a config folder.
jupyter notebook --generate-config
The Python Command Prompt with the command to create the config file
  1. Navigate to the following folder location:
C:\Users\[USER]\.jupyter
  1. Open the jupyter_notebook_config.py file using a text editor, for example, Notepad++.
  2. Search for the comment, The directory to use for notebooks and kernels.
  3. Uncomment the line below it by removing the # symbol, and insert the desired directory. For example:
## The directory to use for notebooks and kernels.
c.NotebookApp.notebook_dir = r'C:\Users\User\Desktop\Work\test'
The jupyter_notebook_config file
  1. Run Jupyter Notebook using the Python Command Prompt using the jupyter notebook command.
Article ID: 000018832
Software:
  • ArcGIS Pro
  • ArcGIS API for Python
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
