ERROR
ArcGIS Server: A root or intermediate certificate cannot be used as a Web server's SSL certificate
First Published: April 14, 2024
Last Published: April 14, 2024
Error Message
When importing a Certificate Authority (CA)-signed certificate to ArcGIS Server, the following error message is returned:
Error:
Cause
A CA-signed certificate might not be fully imported into ArcGIS Server due to the following reasons:
  • Incorrect formatting or mismatches in certificate information.
  • There are missing intermediate/root certificates.
Solution or Workaround
The following workaround may require the assistance of the organization's IT team.
  1. Export an existing CA-signed certificate from the organization's certificate store. Refer to ArcGIS Server: Server certificates for more information.
To obtain a new CA-signed certificate, refer to ArcGIS Server: Generate a new CA-signed certificate for instructions and more information.
  1. Import the full certificate to ArcGIS Server. Refer to ArcGIS Server: Import the certificate into ArcGIS Server for instructions and more information.
  2. Replace the current certificate with the imported CA-signed certificate. Refer to ArcGIS Server: Configure ArcGIS Server to use the certificate for instructions and more information.
Article ID: 000032252
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
