ERROR
a port number must be specified as the last field in the first line of the service.txt file. The recommended range is 27000 to 27009
Last Published: October 26, 2023
Error Message
When attempting to import ArcGIS Pro Named User licenses into ArcGIS License Manager, the import process is halted, and the following error message is returned:
Error:
Error: a port number must be specified as the last field in the first line of the service.txt file. The recommended range is 27000 to 27009.
The error: a port number must be specified as the last field in the first line of the server.txt. file. The recommended range is 27000 to 27009.  returned in ArcGIS License Manager
Cause
The ArcGIS License Manager service.txt file is incorrectly configured and contains a symbol in the port range section.
Solution or Workaround
To resolve the error, open the ArcGIS License Manager service.txt file, and edit the file to ensure there are no symbols in the port range.
  1. Navigate to the following directory on the host machine, and open the service.txt file.
C:\Program Files\ArcGIS\LicenseManager\bin
  1. Ensure the first two lines of the file follow the format below. Remove all unnecessary symbols or characters.
SERVER this_host ANY 27000
VENDOR ARCGIS PORT=<portvalue>
Any value between 27000 and 27009 can be used for VENDOR ARCGIS PORT.
  1. Save the new default service.txt file on the desktop.
  2. Navigate to the directory in Step 1, and rename the service.txt file to service.txt_old.
  3. Copy the new default service.txt saved in Step 3, and paste it in the directory provided in Step 1.
Article ID: 000026848
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
