ERROR
Error 1310: Error writing to file: C:\ArcGIS\Pro\bin\ArcGIS.Core.dll. Verify that you have access to that directory
First Published: October 7, 2024
Last Published: October 3, 2025
Error Message
When running the patch file to upgrade ArcGIS Pro, the following error is returned:
Error 1310:
Error writing to file: C:\ArcGIS\Pro\bin\ArcGIS.Core.dll. Verify that you have access to that directory.
Error 1310 dialog box
Cause
There are several possible causes. Different scenarios indicate that the error is likely due to the installation or upgrade process requiring administrative privileges to write to specific directories.
Solution or Workaround
Even if the user is logged in as an administrator, certain installer operations are performed in the system context, which might require explicit permission settings. To address this, please follow these steps:
  1. Open an elevated Command Prompt, right-click the Start Menu icon and select Windows PowerShell (Admin).
    (Windows Terminal can also be used if it is installed.)
Running the .msp file in the elevated PowerShell bypasses potential file access issues that might arise from restricted permissions on certain system directories.
  1. Run the installation file; click the Yes button in the User Account Control dialog to allow changes to the device.
UAC prompt
  1. In the Command Prompt, navigate to the directory where the install file is located.
  2. Run the installation file. This file has the extension .msp.
    Running .msp file
    Article ID: 000033325
    Software:
    • ArcGIS Pro
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
