HOW TO
The Canadian Geodetic Survey (CGS) developed and maintains the NTv2 tool (National Transformation version 2) for performing geographic (2D) coordinate transformations between NAD27, ATS77, NAD83(Original), and NAD83(CSRS). The transformations in this tool are based on Grid Shift Files (.GSB file type) defined for specific provinces of Canada. While these transformations ship with the supplementary ArcGIS Coordinate Systems Data software component for ArcGIS Pro and ArcGIS Enterprise, users may need to generate custom versions of them for use in other applications. The Create Custom Geographic Transformation (Data Management) geoprocessing tool can be used to generate custom .gtf files based on .GSB files downloadable from the Natural Resources Canada website.
C:\Users\<USERNAME>\AppData\Roaming\Esri\ArcGISPro\ArcToolbox\CustomTransformations
This workflow can be used to generate custom NTv2 transformations for data in regions outside of Canada, provided that the .GSB file is obtained from an authoritative source. The NTv2 format was originally developed by the Canadian Geodetic Survey (CGS), but has been adopted for use in other countries.
Article ID: 000037504
Get help from ArcGIS experts
Start chatting now
