HOW TO
Convert a text field to a date field in ArcMap
First Published: May 5, 2016
Summary
Starting at the 10.0 version of ArcGIS Desktop, a geoprocessing tool has been included that allows for the conversion of a text field that contains dates or times to a formatted date field.
Instructions provided describe the steps for using the 'Convert Time Field geoprocessing tool. In this article's example, the time format 'yyyyMMdd' is used.
[O-Image]
Procedure
  1. Open ArcMap and add the layer or table that includes the text field to be converted to a formatted date field.
  2. Open the Convert Time Field geoprocessing tool: ArcToolbox > Data Management Tools > Fields > Convert Time Field.
  3. Populate the Input fields:
    1. From the Input Table drop-down menu, select the layer or table that contains the field to be converted.
    2. From the Input Time Field drop-down, select the name of the text field to be converted.
      The Input Time Format field should be automatically populated. In this example its current time format (ex: yyyyMMdd)
[O-Image]
The Convert Time Field tool supports over 30 different pre-designated time and date formats.
  1. Populate the Output fields:
    1. Create a name for the new date field under Output Time Field.
    2. From the Output Time Type drop-down select DATE.
The Output Time Format and Locale fields are not selectable for the time type DATE. Select type 'TEXT', 'LONG', or any other type if a different time format for the output is desired.
  1. Click OK. The process completes and the dialog box closes. The date field is formatted to MM/dd/yyyy by default.
[O-Image]
Article ID: 000008953
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
