HOW TO
Convert a text field to a date field in ArcGIS Pro
Last Published: May 31, 2024
Summary
In ArcGIS Pro, the Convert Temporal Field tool converts time values of a string or numeric field to a date field. The tool can also be used to convert time values stored in string, numeric, or date fields into custom formats, such as days and months.
The instructions provided describe how to use the Convert Temporal Field tool in ArcGIS Pro to convert a text field to a date field in an attribute table. The DATE_V field in the Nbo_Hood_Clip attribute table shown in the image below is converted to a DATE field in this example.
The Nbo_Hood_Clip attribute table in ArcGIS Pro
Procedure
  1. Start ArcGIS Pro and open the project.
  2. On the ArcGIS Pro ribbon, click Analysis > Tools to open the Geoprocessing pane.
The ArcGIS Pro Analysis tab
  1. In the Geoprocessing tool search pane, search for Convert Temporal Field in the search bar, and click Convert Temporal Field (Data Management Tools).
ArcGIS Pro Geoprocessing tool search pane
  1. In the Convert Temporal Field pane, configure the following parameters.
    1. For Input Table, select the attribute table.
    2. For Input Field, select the field with the time values.
    3. For Input Format, select the date format of the field with the time values.
    4. For Output Field Name, define the name of the new converted field.
Refer to ArcGIS Pro: Convert Temporal Field (Data Management) for further information on the parameters in the Convert Time Field pane.
  1. Click Run.
ArcGIS Pro Convert Temporal Field pane
Article ID: 000026575
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 3
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
