HOW TO
Convert a shapefile from polygon Z geometry to polygon geometry
Summary
The instructions provided describe how to convert a polygon Z geometry to a polygon geometry shapefile. This procedure removes Z values from the output.
Procedure
  1. Open the Feature Class to Feature Class geoprocessing tool.
    • In Catalog, expand the folder Toolboxes > System Toolboxes > Conversion Tools.tbx > To Geodatabase > Feature Class to Feature Class.
  2. Click the Environments button to access the Environment Settings dialog.
  3. Expand Z Values and set the Output has Z Values to Disabled.
[O-Image]
  1. Click OK to return to the Feature Class to Feature Class tool.
  2. Fill in the other required fields and click OK.
[O-Image]
Article ID: 000012075
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
