BUG
Internet Explorer script errors are generated when running any geoprocessing tool from ArcToolbox on some systems that implement folder redirection
Last Published: July 20, 2023
This issue is fixed in ArcGIS Desktop 10.6.
On some systems that implement Folder Redirection and Roaming Profiles, an Internet Explorer Script error is generated when running any Geoprocessing tool in ArcToolbox. The error is similar to the screen shot below:
An error has occurred in the script of this page.
The error usually appears three times, then the tool opens successfully.
Cause
This is a known issue. A permanent solution was implemented in ArcGIS Desktop 10.6, for previous versions, use the following workarounds.
If similar error messages are being returned but Folder Redirection or Roaming Profiles are not being implemented, refer to the article in the Related Information section below.
Workaround
For version 9.x and earlier, use the following steps.
  1. Close ArcMap and ArcCatalog.
  2. Download the following compressed ZIP file: ver9x.zip.
  3. There are two files in the ZIP file: MdDlgContent.xsl and MdDlgHelp.xsl. Unzip the contents of the ZIP file to the desktop or a desired location on the hard drive.
  4. In Windows Explorer, navigate to the Stylesheets folder in the ArcGIS installation folder. This is usually located at:
C:\Program Files\ArcGIS\ArcToolbox\Stylesheets
  1. In the Stylesheets folder, rename MdDlgContent.xsl to MdDlgContent.xsl_old and rename MdDlgHelp.xsl to MdDlgHelp.xsl_old.
  2. Copy the two new files that were extracted from the ZIP file to the Stylesheets folder. The contents of the folder should look like the screen shot below.
The geoprocessing tools open without error.
The Stylesheets folder window displaying the extracted files.
For version 10.0 through 10.5, use the following steps:
  2. Download the following compressed ZIP file: ver10.zip.
To download the ZIP file, copy and paste the link to a new browser.
  1. There are two files in the ZIP file: MdDlgContent.xsl and MdDlgHelp.xsl. Unzip the contents of the ZIP file to the desktop or a desired location on the hard drive.
  2. In Windows Explorer, navigate to the Stylesheets folder in the ArcGIS installation folder. This is usually located at:
C:\Program Files\ArcGIS\Desktop10.0\ArcToolbox\Stylesheets
Article ID: 000011008
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
