HOW TO
Hochladen von Fotos in den Site Scan Manager for ArcGIS
Last Published: September 7, 2023
Zusammenfassung
After flying a survey with the Site Scan Flight for ArcGIS mobile app, photos can be uploaded either directly from the app or from a computer using Site Scan Manager for ArcGIS. Refer to How To: Transfer drone images to an iPad and manage them in Site Scan for ArcGIS for more information.
Vorgehensweise
Use the Site Scan Flight for ArcGIS app
  1. In Site Scan Manager, tap on Projects. Navigate to the project selected before performing the flight.
  2. Inside the project is a flight list. If the newest flight is not listed, connect the iPad's Wi-fi and open the Site Scan Flight app to sync the new data.
Image showing the Flight Planning app window
  1. After selecting the corresponding flight performed, the screen changes to the map view. Note that the flight does not contain data and the user interface tabs are inactive.
Image showing map view
  1. Upload the photos to the empty flight using the plus (+) button at the bottom-left corner of the screen.
  2. Tap Photos from the menu, and the Edit Flight window opens.
Image showing Edit Flight window
  1. In the Edit Flight window, drag and drop the images to upload, or browse for a location on the computer using the Upload Photos button.
Image showing Upload Photos button
  1. After uploading and saving the images, start processing the flight by clicking the gear icon, next to the plus sign button at the bottom-left of the screen.
  2. In the Confirm Processing window, click Process.
Image showing Confirm Processing window
Uploading images to Site Scan for ArcGIS Manager without using the Site Scan for ArcGIS Flight Planning app
  1. From the Projects menu, select the project to upload the photos to.
  2. Click the New Flight button to open a New Flight window.
Image showing New Flight window
  1. Enter a Flight Name and click Save.
Image showing to click Save
  1. In the Edit Flight window, drag and drop the photos to the window, or click the Upload Photos to browse for them on the computer.
Image showing to click Upload Photos
  1. After uploading and saving the photos, start processing the flight by clicking the gear icon on the bottom-left corner.
Image showing to click Process
Artikel-ID:000023028
Technischen Support kontaktieren
Zu den Download-Optionen
Zugehörige Informationen
