HOW TO
Erstellen fortlaufender Zahlen in einem Feld in ArcMap mithilfe von Python in der Feldberechnung
Last Published: July 18, 2025
Zusammenfassung
Instructions provided describe how to create sequential numbers in a field in ArcMap using Python in the Field Calculator.
Vorgehensweise
The code in this article generates sequential numbers for unsorted data based on the OID or FID order. If the data is sorted on a field, the generated numbers are not sequential.
  1. Create a new short integer field. Refer to ArcMap: Adding fields for instructions.
  2. Right-click the new field and select Field Calculator.
  3. Set the Parser to Python.
  4. Check the check box for Show Codeblock.
  5. Paste the following into the Pre-Logic Script Code:
rec=0
def autoIncrement():
 global rec
 pStart = 1
 pInterval = 1
 if (rec == 0):
  rec = pStart
 else:
  rec += pInterval
 return rec
  1. Paste the following code in the smaller box below the Pre-Logic Script Code:
autoIncrement()
  1. Click OK. The following image is an example of a field with sequential numbers populated using the Python code:
An attribute table with a field with sequential numbers.
Artikel-ID: 000011137
Zugehörige Informationen
Zu Download-Optionen wechseln
