HOW TO
Erstellen von Verbindungslinien zwischen zwei Punkten aus einer CSV-Datei
Last Published: July 20, 2023
Zusammenfassung
In ArcGIS Pro, connection lines can be created between two points from a CSV file using the Points To Line tool. To ensure the connection lines created in ArcGIS Pro are precise, the CSV file must contain the coordinate data of the points, and the matching unique attribute values to identify the connection between the two points, as shown in the image below.
A CSV file with X and Y coordinate data, and the unique values for the sets of points.
Vorgehensweise
Follow the steps below to create the connection lines between two points from a CSV file in ArcGIS Pro.
  1. In ArcGIS Pro, import the CSV file as a standalone table to the project. Refer to ArcGIS Pro Intelligence: Connect to data sources and add data to a map for more information.
  2. In the Contents pane, right-click the standalone table, and click Display XY Data from the drop-down menu.
  3. In the Display XY Data dialog box, configure the required parameters.
    1. For Output Feature Class, specify the location and name for the new point feature layer.
    2. For X Field and Y Field, select the attribute field from the drop-down list.
    3. For Coordinate System, click the Select coordinate system The Select coordinate system button icon in ArcGIS Pro. button, specify a coordinate system from the Coordinate Systems Available list in the Coordinate System dialog box, and click OK.
    4. In the Display XY Data dialog box, click OK.
  4. In ArcGIS Pro, click Tools from the Geoprocessing group of the Analysis tab.
The Tools option in the Geoprocessing group of the Analysis tab in ArcGIS Pro.
  1. In the Geoprocessing pane, type Point To Line in the Find Tools search bar, and click the Points To Line tool from the drop-down list.
In ArcGIS Pro, type 'Point To Line' in the Find Tools search bar, and click the Point To Line tool in drop-down list in the Geoprocessing pane.
  1. In the Points To Line geoprocessing pane, configure the required parameters.
    1. For Input Features, select the new point layer from the drop-down list.
    2. For Output Feature Class, specify the location and name for the new line feature layer.
    3. For Line Field, select the field with the unique attribute values from the drop-down list. In this example, the Unique ID field is selected.
The Unique ID field is selected in the Line Field Parameter of the Point To Line geoprocessing pane in ArcGIS Pro.
  1. Click Run.
The image below demonstrates the connection lines created between two points from a CSV file using the Display XY Data option and Points To Line tool in ArcGIS Pro.
The line connections between two points created using the Display XY Data option and the Point To Line tool in ArcGIS Pro.
Artikel-ID: 000027447
Zugehörige Informationen
Zu Download-Optionen wechseln
