Häufig gestellte Frage (FAQ)
It is not possible to add or delete related records from a related table of a hosted feature layer in ArcGIS Online Map Viewer or from the Data tab of the Item Details page.
As a workaround to add or delete records from a related table, use the Edit widget in an app created with ArcGIS Web AppBuilder.
Alternatively, it is possible to use ArcGIS Collector to add or delete related records from a related table.
Artikel-ID: 000021186
