ERROR
Administrativer Zugriff ist deaktiviert. Wenden Sie sich an Ihren Systemadministrator, um ihn zu aktivieren.
Last Published: May 16, 2024
Fehlermeldung
In some instances, when attempting to access the Portal Administrator Directory, the following error message is returned:
Error:
Administrative access is disabled. Please contact your system administrator to enable it.
The error: Administrative access is disabled. Please contact your system administrator to enable it is returned when accessing the ArcGIS Portal Administrator Directory site
Ursache
  • The web adaptor is not configured to allow administrative access.
  • The incorrect URL is used to access the Portal Administrator Directory.
Lösung oder Problemumgehung
To resolve the error, configure the web adaptor to enable administrative access to the site. Refer to ArcGIS Enterprise: Configuring the Web Adaptor from the configuration web page for more information. If the issue persists, ensure the Portal Administrator Directory URL follows the format below:
https://webadaptorhost.domain.com/webadaptorname/portaladmin
Artikel-ID: 000026115
Zugehörige Informationen
Zu Download-Optionen wechseln
