English
How To: Convert a Polygon Z geometry to a Polygon geometry shapefile
Summary
The instructions provided describe how to convert a Polygon Z geometry to a Polygon geometry shapefile.
Procedure
  1. Open the Feature Class to Feature Class tool (double-click).
    In ArcCatalog, expand the folder Toolboxes > System Toolboxes > Conversion Tools.tbx > To Geodatabase > Feature Class to Feature Class.
  2. Click the Environments button to access the Environment Settings.
  3. Expand Z Values and set the 'Output has Z Values' to Disabled.
    [O-Image]
  4. Click OK to return to the Feature Class to Feature Class tool.
  5. Fill in the other required fields and click OK.
    [O-Image]
Related Information
