HOW TO
Create sequential numbers in a field in ArcMap using Python in the Field Calculator
Last Published: April 19, 2024
Summary
Instructions provided describe how to create sequential numbers in a field in ArcMap using Python in the Field Calculator.
ArcMap is in Mature support and will be retired March 1, 2026. There are no plans for future releases of ArcMap, and it is recommended that you migrate to ArcGIS Pro. See Migrate from ArcMap to ArcGIS Pro for more information.
Procedure
The code in this article generates sequential numbers for unsorted data based on the OID or FID order. If the data is sorted on a field, the generated numbers are not sequential.
  1. Create a new short integer field. Refer to ArcMap: Adding fields for instructions.
  2. Right-click the new field and select Field Calculator.
  3. Set the Parser to Python.
  4. Check the check box for Show Codeblock.
  5. Paste the following into the Pre-Logic Script Code:
rec=0
def autoIncrement():
 global rec
 pStart = 1
 pInterval = 1
 if (rec == 0):
  rec = pStart
 else:
  rec += pInterval
 return rec
  1. Paste the following code in the smaller box below the Pre-Logic Script Code:
autoIncrement()
  1. Click OK. The following image is an example of a field with sequential numbers populated using the Python code:
An attribute table with a field with sequential numbers.
Article ID:000011137
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
