BUG
Encountering Oracle error ora-4030 when creating a spatial index in Oracle
When creating a spatial index on an st_geometry attribute for a table containing millions of rows, the following Oracle error may be returned:
"ORA-04030: out of process memory when trying to allocate NN bytes".
Cause
The implementation of the spatial index method 'ODCIIndexCrate' uses two Oracle PL/SQL structures: the BULK COLLECT option while array fetching from a cursor, and the FORALL INSERT clause to array an insert into a table. Both of these PL/SQL programming structures have known Oracle memory leaks that can lead to the Oracle error: ORA-04030.
Workaround
To work around the Oracle error, first install the Oracle patch to address the bug below.
Bug:8934457
RDBMS: GETTING ORA-4031 EVEN AFTER FIX FOR BUG 8537544
Refer to Oracle’s Metalink for additional information on the Oracle patch.
Even after applying the Oracle patch, there are still cases that are based on the size of the table (number of rows), where the Oracle error is encountered when creating the spatial index. If the error is returned under these conditions, please contact ESRI Support Services for further assistance.
    Article ID:000010816
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
