- Simple calculations
- Python built-in functions
- Using code blocks
- Code samples—math
- Calculate fields using logic with Python
- Calculate fields using logic with VBScript
- Code samples—geometry
- Geometry unit conversions
- Code samples—dates
- Code samples—strings
- Accumulative and sequential calculations
- Random values
- Calculating null values
Entering values with the keyboard is not the only way you can edit values in a table. In some cases, you might want to perform a mathematical calculation to set a field value for a single record or even all records. You can perform simple as well as advanced calculations on all or selected records. In addition, you can calculate area, length, perimeter, and other geometric properties on fields in attribute tables. The sections below include examples of using the field calculator. Calculations can be performed using either Python or VBScript.
Python is the recommended scripting language for ArcGIS. Use Python if you want access to geoprocessing functionality, including feature geometry. The adoption of Python as the scripting language for ArcGIS provides many opportunities for performing calculations.
Use VBScript if you have VBA or VBScript experience and are comfortable with the scripting syntax. Saved .cal files from previous versions of ArcGIS may work or require minimal modifications. If you have VBA code from past releases that use ArcObjects, you will need to modify your calculations.
Simple calculations
Simple string examples
Strings are supported by a series of Python string functions, including capitalize, rstrip, and replace.
Capitalize the first character of the string in the field CITY_NAME.
!CITY_NAME!.capitalize()
Strip any white space from the end of the string in the field CITY_NAME.
!CITY_NAME!.rstrip()
Replace any occurrences of "california" with "California" found in the field STATE_NAME.
!STATE_NAME!.replace("california", "California")
Characters in a string field can be accessed by indexing and slicing in Python. Indexing fetches characters at an index position; slicing fetches a group of characters. In the following table, assume that !fieldname! is a string field with a value of "abcde".
Example | Explanation | Result |
!fieldname![0] | The first character. | "a" |
!fieldname![-2] | The second-to-last character. | "d" |
!fieldname![1:4] | The second, third, and fourth characters. | "bcd" |
Python also supports string formatting using the str.format() method.
Combine FieldA and FieldB separated by a colon.
"{}:{}".format(!FieldA!, !FieldB!)
VBScript string functions
Strings are supported by a series of VBScript string functions, including Left, InStr, and Chr. Below are some VBScript examples for commonly used string functions in the Field Calculator.
Left function: Return a Variant (String) containing a specified number of characters from the left side of a string.
MyStr = Left([MyField], 1)
Right function: Returns a Variant (String) containing a specified number of characters from the right side of a string.
MyStr = Right([MyField], 1)
Mid function: Returns a Variant (String) containing a specified number of characters from a string.
MyString = "Mid Function Demo" 'Create text string
FirstWord = Mid(MyString, 1, 3) ' Returns "Mid"
LastWord = Mid(MyString, 14, 4) 'Returns "Demo"
MidWords = Mid(MyString, 5) 'Returns "Function Demo"
InStr function: Returns a Variant (Long) specifying the position of the first occurrence of one string within another.
MyPosition = InStr([address], " ")
Replace function: Returns a string in which a specified substring has been replaced with another substring a specified number of times.
NewString = Replace([comments], "#", "!")
Chr function: Returns a String containing the character associated with the specified character code.
' Replace a carriage return character with an exclamation
NewString = Replace([comments], chr(13), "!")
& operator: Used to force string concatenation of two expressions.
MyStr = [MyField1] & " " & [MyField2]
Simple math examples
Python provides tools for processing numbers. Python also supports a number of numeric and mathematical functions, including math, cmath, decimal, random, itertools, functools, and operator.
Operator | Explanation | Example | Result |
x + y | x plus y | 1.5 + 2.5 | 4.0 |
x - y | x minus y | 3.3 - 2.2 | 1.1 |
x * y | x times y | 2.0 * 2.2 | 4.4 |
x / y | x divided by y | 4.0 / 1.25 | 3.2 |
x // y | x divided by y (floor division) | 4.0 / 1.25 | 3.0 |
x % y | x modulo y | 8 % 3 | 2 |
-x | negative expression of x | x = 5 -x | -5 |
+x | x is unchanged | x = 5 +x | 5 |
x ** y | x raised to the power of y | 2 ** 3 | 8 |
Multiplication
!Rank! * 2
Calculate volume of a sphere given a radius field.
4 / 3 * math.pi * !Radius! ** 3
When performing field calculations with a Python expression, Python math rules are in effect. For example, dividing two integer values will always produce an integer output (3 / 2 = 1). Produce a decimal output in the following ways:
- One of the numbers in the operation must be a decimal value: 3.0/2 = 1.5.
- Use the float function to
explicitly convert the value to a float:
float(3)/2 = 1.5
float(!Population!) / !Area!
Python has a number of built-in functions that are available to use, including max, min, round, and sum.
Calculate the maximum value for each record from a list of fields.
max([!field1!, !field2!, !field3!])
Calculate the sum for each record from a list of fields.
sum([!field1!, !field2!, !field3!])
Using code blocks
With Python expressions and the Code Block parameter, you can do the following:
- Use any Python function in the expression.
- Access geoprocessing functions and objects.
- Access properties of feature geometry.
- Access the new random value operator.
- Reclassify values using if-then-else logic.
How the code block is used is determined by the parser used. The Field Calculator supports Python and VBScript parsers.
Parser | Code Block |
Python | Supports Python functionality. The code block is expressed using Python functions (def). Geometry properties are expressed using geoprocessing objects, such as Point objects, where appropriate. |
VBScript | Calculations are performed using VBScript. |
Python functions are defined using the def keyword followed by the name of the function and the function’s input arguments. A Python function can be written to accept any number of input arguments (including none at all). Values are returned from the function using a return statement. The function name is your choice (don't use spaces or leading numbers).
Code samples—math
Round a field's value to two decimal places.
Expression:
round(!area!, 2)
Parser:
Python
Use the math module to help convert meters to feet. The conversion is raised to the power of 2 and multiplied by the area.
Parser:
Python
Expression:
MetersToFeet((float(!shape.area!)))
Code Block:
def MetersToFeet(area):
return math.pow(3.2808, 2) * area
Classify based on field values.
Parser:
Python
Expression:
Reclass(!WELL_YIELD!)
Code Block:
def Reclass(WellYield):
if (WellYield >= 0 and WellYield <= 10):
return 1
elif (WellYield > 10 and WellYield <= 20):
return 2
elif (WellYield > 20 and WellYield <= 30):
return 3
elif (WellYield > 30):
return 4
Conditionally executes a group of statements, depending on the value of an expression.
Parser:
VB Script
Expression:
density
Code Block:
Dim density
If [POP90_SQMI] < 100 Then
density = "low"
elseif [POP90_SQMI] < 300 Then
density = "medium"
else
density = "high"
end if
Calculate the area of a feature.
Parser:
Python
Expression:
!shape.area!
Calculate the maximum x-coordinate of a feature.
Parser:
Python
Expression:
!shape.extent.XMax!
Calculate the vertex count of a feature.
Parser:
Python
Expression:
MySub(!shape!)
Code Block:
def MySub(feat):
partnum = 0
# Count the number of points in the current multipart feature
partcount = feat.partCount
pntcount = 0
# Enter while loop for each part in the feature (if a singlepart
# feature this will occur only once)
while partnum < partcount:
part = feat.getPart(partnum)
pnt = part.next()
# Enter while loop for each vertex
while pnt:
pntcount += 1
pnt = part.next()
# If pnt is null, either the part is finished or there
# is an interior ring
if not pnt:
pnt = part.next()
partnum += 1
return pntcount
For a point feature class, shift the x-coordinate of each point by 100.
Parser:
Python
Expression:
shiftXCoordinate(!SHAPE!)
Code Block:
def shiftXCoordinate(shape):
shiftValue = 100
point = shape.getPart(0)
point.X += shiftValue
return point
Area and length properties of the geometry field can be modified with unit types expressed with an @ sign.
- Areal unit of measure keywords:
- ACRES | ARES | HECTARES | SQUARECENTIMETERS | SQUAREDECIMETERS | SQUAREINCHES | SQUAREFEET | SQUAREKILOMETERS | SQUAREMETERS | SQUAREMILES | SQUAREMILLIMETERS | SQUAREYARDS | SQUAREMAPUNITS | UNKNOWN
- Linear unit of measure keywords:
- CENTIMETERS | DECIMALDEGREES | DECIMETERS | FEET | INCHES | KILOMETERS | METERS | MILES | MILLIMETERS | NAUTICALMILES | POINTS | UNKNOWN | YARDS
Calculate a feature's length in yards.
Parser:
Python
Expression:
!shape.length@yards!
Calculate a feature's area in acres.
Parser:
Python
Expression:
!shape.area@acres!
Geodesic area and length can also be calculated using geodesicArea and geodesicLength properties with @ followed by a unit of measure keyword.
Calculate a feature's geodesic length in yards.
Parser:
Python
Expression:
!shape.geodesicLength@yards!
Calculate a feature's geodesic area in acres.
Parser:
Python
Expression:
!shape.geodesicArea@acres!
Code samples—dates
Calculate the current date.
Parser:
Python
Expression:
time.strftime("%d/%m/%Y")
Calculate the current date and time.
Parser:
Python
Expression:
datetime.datetime.now()
Calculate the date to be December 31, 2000.
Parser:
Python
Expression:
datetime.datetime(2000, 12, 31)
Calculate the number of days between the current date and the value in a field.
Parser:
Python
Expression:
(datetime.datetime.now() - arcpy.time.ParseDateTimeString(!field1!)).days
Calculate a date by adding 100 days to the date value in a field.
Parser:
Python
Expression:
arcpy.time.ParseDateTimeString(!field1!) + datetime.timedelta(days=100)
Calculate the day of the week (for example, Sunday) for a date value in a field.
Parser:
Python
Expression:
arcpy.time.ParseDateTimeString(!field1!).strftime('%A')
Return the three rightmost characters.
Parser:
Python
Expression:
!SUB_REGION![-3:]
Replace any cases of an uppercase P with a lowercase p.
Parser:
Python
Expression:
!STATE_NAME!.replace("P","p")
Concatenate two fields with a space separator.
Parser:
Python
Expression:
!SUB_REGION! + " " + !STATE_ABBR!
Convert to proper case
The following examples show different ways to convert words so that each word has the first character capitalized and the rest of the letters in lowercase.
Parser:
Python
Expression:
' '.join([i.capitalize() for i in !STATE_NAME!.split(' ')])
Parser:
Python
Expression:
!STATE_NAME!.title()
Regular expressions
Python's re module provides regular expression matching operations that can be used to perform complex pattern matching and replacement rules for strings.
Replace St or St. starting new words at the end of the string with the word Street.
Parser:
Python
Expression:
update_street(!ADDRESS!)
Code Block:
import re
def update_street(street_name):
return re.sub(r"""\b(St|St.)\Z""",
'Street',
street_name)
Calculate a sequential ID or number based on an interval.
Parser:
Python
Expression:
autoIncrement()
Code Block:
rec=0
def autoIncrement():
global rec
pStart = 1 #adjust start value, if req'd
pInterval = 1 #adjust interval value, if req'd
if (rec == 0):
rec = pStart
else:
rec = rec + pInterval
return rec
Calculate the accumulative value of a numeric field.
Parser:
Python
Expression:
accumulate(!FieldA!)
Code Block:
total = 0
def accumulate(increment):
global total
if total:
total += increment
else:
total = increment
return total
Calculate the percentage increase of a numeric field.
Parser:
Python
Expression:
percentIncrease(float(!FieldA!))
Code Block:
lastValue = 0
def percentIncrease(newValue):
global lastValue
if lastValue:
percentage = ((newValue - lastValue) / lastValue) * 100
else:
percentage = 0
lastValue = newValue
return percentage
Random values
Use the numpy site package to calculate random float values between 0.0 and 1.0.
Parser:
Python
Expression:
getRandomValue()
Code Block:
import numpy
def getRandomValue():
return numpy.random.random()
Using a Python expression, null values can be calculated using a Python None.
Use a Python None to calculate null values.
Parser:
Python
Expression:
None
