English
Error: Error 1606: Could not access the network location
Error Message
When attempting to add, remove, or change the installation of ArcGIS products, the following error may occur:
Error:
"Error 1606: Could not access the network location."
Cause
This issue may occur if there is an incorrect setting in one of the registry keys related to Shell Folders.
Solution or Workaround
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
Verify that the values that correspond to user Shell Folders are set correctly and have a valid value.
  1. Navigate to Start > Run, type 'regedit.exe', and then click OK.
  2. Navigate to
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders.
  3. On the right hand side, verify that the values are the same as the values in the following table. If each value matches the table, go to step 7.
    Windows XP and Windows Server 2003
    Value Name     Value Data
    AppData        %USERPROFILE%\Application Data
    Cache          %USERPROFILE%\Local Settings\Temporary Internet Files
    Cookies        %USERPROFILE%\Cookies
    Desktop        %USERPROFILE%\Desktop
    Favorites      %USERPROFILE%\Favorites
    History        %USERPROFILE%\Local Settings\History
    LocalAppData   %USERPROFILE%\Local Settings\Application Data
    Local Settings %USERPROFILE%\Local Settings
    My Pictures    %USERPROFILE%\My Documents\My Pictures
    NetHood        %USERPROFILE%\NetHood
    Personal       %USERPROFILE%\My Documents
    PrintHood      %USERPROFILE%\PrintHood
    Programs       %USERPROFILE%\Start Menu\Programs
    Recent         %USERPROFILE%\Recent
    SendTo         %USERPROFILE%\SendTo
    Start Menu     %USERPROFILE%\Start Menu
    Startup        %USERPROFILE%\Start Menu\programs\Startup
    Templates      %USERPROFILE%\Templates
    Windows Vista, Windows 7 and Windows Server 2008
    {374DE290-123F-
    4565-9164-
    39C4925E467B}  %USERPROFILE%\Downloads
    AppData        %USERPROFILE%\AppData\Roaming
    Cache          %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
    Cookies        %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
    History        %USERPROFILE%\AppData\Local\Microsoft\Windows\History
    LocalAppData   %USERPROFILE%\AppData\Local
    My Pictures    %USERPROFILE%\Pictures
    My Music       %USERPROFILE%\Music
    My Video       %USERPROFILE%\Videos
    NetHood        %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
    Personal       %USERPROFILE%\Documents
    PrintHood      %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
    Programs       %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
    Recent         %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
    SendTo         %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
    Start Menu     %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
    Startup        %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
    Templates      %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
  4. If any Name or Value does not match the table in step 3, right-click the Value name, and then click Delete.
  5. On the left side, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that was just deleted from the table in step 3, and then press ENTER to create the variable.
  6. Right-click the value that was created in step 5, click Modify, type the value in the Value data box for the Value name, and then click OK.
Repeat steps 5 and 6 for any of the values that were deleted.
  1. Navigate to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders.
  2. On the right side, verify that the values are the same as the values in the following table. If each value matches the table, go to step 12.
    Value name        Value data
    Common AppData    %ALLUSERSPROFILE%\Application Data
    Common Desktop    %ALLUSERSPROFILE%\Desktop
    Common Documents  %ALLUSERSPROFILE%\Documents
    Common Favorites  %ALLUSERSPROFILE%\Favorites
    Common Programs   %ALLUSERSPROFILE%\Start Menu\Programs
    Common Start Menu %ALLUSERSPROFILE%\Start menu
    Common Startup    %ALLUSERSPROFILE%\Start Menu\Programs\Startup
    Common templates  %ALLUSERSPROFILE%\Templates
    {3D644C9B-1FB8-
    4f30-9B45-
    F670235F79C0}     %PUBLIC%\Downloads
    Common AppData    %ProgramData%
    Common Desktop    %PUBLIC%\Desktop
    Common Documents  %PUBLIC%\Documents
    Common Programs   %ProgramData%\Microsoft\Windows\Start Menu\Programs
    Common Start Menu %ProgramData%\Microsoft\Windows\Start Menu
    Common Startup    %ProgramData%\Microsoft\Windows\Start Menu\Programs\Startup
    Common templates  %ProgramData%\Microsoft\Windows\Templates
    CommonMusic       %PUBLIC%\Music
    CommonPictures    %PUBLIC%\Pictures
    CommonVideo       %PUBLIC%\Videos
  3. If any Name or Value does not match the table in step 3, right-click the Value name, and then click Delete.
  4. On the left hand side, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that was removed from the table in step 3, and then press ENTER.
  5. Right-click the value that was created in step 5, click Modify, type the value in the Value data box for the Value name, and then click OK.
Again repeat steps 10-11 for each of the values that was removed.
  1. Close the Registry Editor, and then restart the computer.
Related Information
