English
How To: Export a layer from ArcMap to a geodatabase feature class
Summary
You can export an layer in ArcMap to a Geodatabase feature class.
Procedure
  1. Start ArcMap and add data to the Data Frame, if needed.
  2. Right-click the layer to be exported.
  3. Select Data > Export Data.
  4. Click the Browse button.
  5. Change the output type dropdown list to Personal geodatabase feature class.
  6. Navigate to the geodatabase where you want to save the output.
  7. Click the Save button.
  8. Click OK.
