English
How To: Remove red exclamation points and relocate an ArcMap data source
Summary
Instructions provided describe how to remove red exclamation points and relocate an ArcMap data source. When data has been relocated after the creation of an ArcMap .mxd, relative path names no longer work. A red exclamation point appears next to the feature classes in the ArcMap table of contents.
Procedure
Follow the steps below.
  1. Right-click the layer with the red exclamation mark.
  2. Click Data > Set Data Source.
  3. Navigate to the location of the data.
  4. Click Add.
    All other data that has been moved from the same .mxd and is relocated in the same folder is updated automatically.
