常见问题
Geocoded address points display along the street, rather than on the building, because the StreetMap Premium point locators default to show the location of a matched address as the entry point on the street to the parcel or building centroid. The geocoding result contains fields named 'DisplayX' and 'DisplayY'; these fields store the decimal degree coordinates for the parcel or building centroid associated with each address as the geocoded point feature is located on the street segment near the main entrance to the property.
All StreetMap Premium PointAddress locators provide the ability to change the default location of a matched address from the entry point on the street to the parcel or building centroid, though the results may not show the change. Whether the point address locates on the parcel depends on whether the reference data includes the exact parcel location. Reference data sources vary by country, so some countries may have the exact parcel location and others may not.
To make the change to get the exact parcel location, follow these steps.
In ArcMap:
Note: After making a change to the locator settings, you will need to remove and read the locator to the map in order for the changes to take effect.
In ArcGIS Pro:
文章 ID: 000001067
获取来自 ArcGIS 专家的帮助
立即开始聊天
