问题
问题:协调版本时出现意外冲突
Last Published: May 6, 2024
描述
Versioning workflow issues may be a cause of unexpected conflicts when reconciling. This issue has to do with workflow and the correct reconcile order.
An example is when creating a new child version mid-way through a workflow without performing a compress. More specifically, conflicts may appear upon reconcile when objects have been modified by the newly created child version. Therefore, workflows must ensure that the parent version is in alignment with their child versions upon creation of the child versions.
解决方案或解决方法
To avoid this, run the Reconcile Versions geoprocessing tool before reconciling with the edits made from a newly created child version, using the following option, as shown in the image below:
  • In the Reconcile Versions geoprocessing tool, under Reconcile Mode, select Reconcile blocking versions only, and click Run.
Under Reconcile Mode, Reconcile blocking versions only is selected
文章 ID: 000025625
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
