错误
错误:下载地图失败。 创建复本失败
错误消息
When downloading a web map for offline use with Collector for ArcGIS iOS or Android, the following error may be returned, as shown in the images below:
"Failed to create replica"
[O-Image]
[O-Image]
原因
This error is returned when working with versioned feature classes that have enabled the option to 'register the selected objects with the option to move edits to base', as shown below. This is an unsupported configuration for versioned data if it is intended to use replication. This limitation this documented: 000769: Cannot create replica because none of the data can be replicated.
[O-Image]
The following entries may also be found in the server logs:
[O-Image]
解决方案或解决方法
There are two options to work around this limitation.
  • Disable the option to move edits to base:
  1. Stop the feature service that references the data.
  2. Unregister the feature class as versioned.
  3. Register the feature class as versioned again, this time unchecking the option to move edits to base.
  4. Start the feature service.
Detailed documentation on using versioned data with offline editing work flows is available: Offline maps and versioned data
文章 ID: 000012535
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
