漏洞
错误:无法从 ArcGIS Pro 2.4.3 Python Package Manager 安装GeoPandas 模块
Last Published: May 6, 2024
描述
At ArcGIS Pro version 2.6, Geopandas fails to install into an ArcGIS Pro Python environment.
原因
This is a known issue that will be resolved in a future release of ArcGIS Pro.
解决办法
Use the following steps to work around the issue:
  1. In ArcGIS Pro, click the Project tab, and then Python to open the Python Package Manager.
  2. Under Project Environment, check that the active environment is not the default environment, arcgispro-py3. If it is, clone the environment before continuing. Learn more about the Python Package Manager.
  3. Once you have confirmed that you are using a cloned Python environment, close ArcGIS Pro and open the command prompt from Windows Start > ArcGIS > Python Command Prompt, then run the following command:
conda install geopandas libtiff=4.0.10
You should now be able to import geopandas from a Python interpreter in your ArcGIS Pro environment.
文章 ID: 000024177
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
