问题
问题:无法在 Portal for ArcGIS 中使用受保护的服务项目存储凭据
Last Published: November 15, 2024
描述
When adding a secure ArcGIS Server web service as an item to Portal for ArcGIS, the option to store credentials with the item is not available. This prevents client applications from consuming a web map using the web service without an initial authentication process with the parent ArcGIS Server site. It also hampers the ease of use of these web maps and web services.
The following error message may be returned in the Portal for ArcGIS log files:
Error:
Invalid SSL certificate found. PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target.
原因
The SSL certificates on the reverse proxy machine hosting the ArcGIS Server web adaptor are untrusted by Portal for ArcGIS.
Portal for ArcGIS uses the checkUrl.jsp utility to determine if it can make outbound requests to the service. If an error occurs during this execution, the option to store credentials is not presented.
解决方案或解决方法
Import the full chain of certificates on the reverse proxy machine hosting the ArcGIS Server web adaptor into the Portal for ArcGIS trusted keystore.
  1. Log on to the reverse proxy machine hosting the ArcGIS Server web adaptor, and export the full chain of certificates in the .cer file format. This is done by the organization's IT department.
  2. Navigate to the Portal for ArcGIS admin endpoint, and log in with an administrator account.
  3. Navigate to Security > SSLCertificates > Import Root or Intermediate.
  4. Select the .cer files generated in Step 1. Portal for ArcGIS restarts after successfully importing the certificates.
  5. Clear the browser cache.
The option to store credentials is presented when adding a secure ArcGIS Server web service as an item to Portal for ArcGIS.
文章 ID: 000023376
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
