操作方法
“符号选择器”对话框显示一个符号调色板,其中的符号来自当前引用的任何样式或用户的个人样式。 通过使用“符号选择器”,如果调色板中没有所需的符号或难以找到,用户可以创建自定义符号。
然而,如果“符号选择器”对话框中的“另存为”按钮被禁用,用户将无法在“符号选择器”中保存自定义符号。
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012396/00N39000003LL24-0EM39000000wdbO.png)
该按钮可能由于以下原因而被禁用:
根据原因,适用以下解决方法:
Note: Close all Esri applications running on the system before proceeding to the workaround.
确保对 .style 文件拥有读写权限
此文件位于:
C:\Users\*username*\AppData\Roaming\ESRI\Desktop10.x\ArcMap
Note: Enable 'Show Hidden Files and Folders' if unable to locate the application data folder. This can be done in Windows 7 or 8 by clicking Organize Drop-down > Folder and Search Options > View Tab > Show Hidden Files and Folders.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012396/00N39000003LL2C-0EM39000000wdbR.png)
重命名 Normal.mxt 文件
C:\User\*username*\AppData\Roaming\ESRI\Desktop10.x\ArcMap\Templates
Warning: The instructions below include making changes to essential parts of the operating system. Esri recommends performing a back up of the operating system and files, including the registry, before proceeding. Consult a qualified computer systems professional if necessary. Be aware that renaming the Esri folders is a factory reset of ArcGIS, and therefore all third party tools, custom scripts, or custom toolbars currently installed must be reinstalled accordingly. Additionally, all existing folder connections must be reconnected. Esri cannot guarantee results from incorrect modifications while following these instructions. Proceed with caution.
Note: If ArcGIS Pro is installed on the machine, ensure that an ArcGIS Pro license is not checked out from ArcGIS Online. If unsure that the ArcGIS Pro license is checked out on the machine, contact Esri Technical Support at 888-377-4575.
重命名 Esri 文件夹
编辑注册表项
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012396/00N39000003LL2C-0EM39000000wdbS.png)
文章 ID: 000012396
获取来自 ArcGIS 专家的帮助
立即开始聊天
