问题
问题:无法在 ArcGIS Pro 中禁用项目的“添加至新工程”选项
Last Published: September 19, 2023
描述
In ArcGIS Pro, frequently used items such as a geodatabase or a folder can be added automatically to new projects by enabling the Add To New Projects option. These items can also be removed from being added to every new project by disabling the Add To New Projects option. In some instances, the Add To New Projects option is unavailable for the item and cannot be disabled. In this example, the option is unavailable for the ProjectFile folder that has enabled the Add to New Projects option.
The Add To New Projects option is unavailable in the list after right-clicking an item that has enabled the Add To New Projects option in the Catalog pane.
原因
The item is a favorite item. When the Add To New Projects option is enabled for an item, the item is simultaneously marked as favorite.
解决方案或解决方法
Follow the workaround below to disable the Add To New Projects option for an item.
  1. In ArcGIS Pro, in the Catalog pane, click Favorites.
Access the Favorites tab by clicking Favorites in the Catalog pane. The Favorites tab is the third tab.
  1. On the Favorites tab, right-click the desired item, and click to uncheck Add To New Projects. The option to automatically add the item to new projects is disabled.
Disable the Add To New Projects option for an item by navigating to the item on the Favorites tab, right-click the item, and click to uncheck Add To New Projects. There is a checkmark indicating the Add To New Projects option is enabled for the item.
The item is still listed on the Favorites tab. Alternatively, select Remove The Remove option on the list with a yellow star, and red x symbol. to remove the item as a favorite item and disable the Add To New Projects option.
文章 ID: 000026728
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
