问题
问题:无法在 ArcGIS Pro 中取消作业
Last Published: September 8, 2023
描述
In some instances, sharing a package in the Create Project Template or Create Vector Tile Package pane fails, and the sharing process cannot be canceled in the Job Status pane in ArcGIS Pro. Force closing ArcGIS Pro does not cancel the job as the sharing process restarts after reopening the application.
原因
The sharing process runs in the background, allowing users to work with ArcGIS Pro. Closing ArcGIS Pro does not end the sharing process as it is a separate process from the jobs processed in ArcGIS Pro.
解决方案或解决方法
If attempting to cancel the task in the Job Status pane fails and the task is still running, end the ArcGISSharingServer.exe process in Windows Task Manager by following the steps below.
The same process is listed as SharingServer DLL in some cases.
  1. On the Windows desktop, right-click the desktop taskbar, and click Start Task Manager.
  2. In Windows Task Manager, click Processes.
Image of the Processes tab in Windows Task Manager
  1. Click ArcGISSharingServer.exe.
  2. Click End Process.
Image showing the Processes tab in Windows Tasks Manager
  1. In the Do you want to end 'ArcGISSharingServer.exe.'? dialog box, click End process.
Image of the Windows Task Manager dialog box
  1. In ArcGIS Pro, in the Job Status pane, click the Cancel icon to cancel the task.
Image of the Job Status pane
文章 ID: 000024380
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
