问题
In ArcGIS Pro, it is possible to modify the field aliases of a feature layer in the fields view, and save the changes on the map. However, after removing the feature layer from the Contents pane, and re-adding it to the map from the project's geodatabase in the Catalog pane, the previously modified field aliases are not preserved.
There are two types of field aliases: feature class field aliases (geodatabase only) and layer field aliases. When opening the Fields view from the Contents pane, top ribbon, or attribute table, the edits are made to the layer field aliases. Therefore, the changes are only saved at the feature layer level.
To resolve the issue, modify the field aliases at the feature class level.
The modified field aliases are preserved at the feature class and feature layer level.
文章 ID: 000024417
获取来自 ArcGIS 专家的帮助
立即开始聊天
