问题
问题:面和线图层的“掩模类型”参数未显示在“要素轮廓线掩模”工具中
First Published: March 11, 2020
描述
In ArcGIS Pro, the Mask Kind parameter does not display in the Feature Outline Masks tool when polygon and line layers are used. Instead, it displays when point and annotation layers are used.
The images below show the Feature Outline Masks pane with a polygon layer as the input layer, and the Mask Kind parameter is not displayed.
Polygon layer
The images below show the Feature Outline Masks pane with a point layer as the input layer, and the Mask Kind parameter is displayed.
Point layer
原因
This is expected behavior for the tool. The Mask Kind parameter only displays when annotation and point layers are used.
解决方案或解决方法
As a workaround, use the batch mode in the Feature Outline Masks tool to display the Mask Kind parameter when the input layer contains both polygon and line layers. The parameter displays because in batch mode, the tool does not pre-validate data to determine the kind of mask to select. Alternatively, use the Buffer or Minimum Bounding Geometry tools. Refer to ArcGIS Pro: Buffer (Analysis) or ArcGIS Pro: Minimum Bounding Geometry (Data Management) for steps and more information.
To open and run a tool in batch mode, refer to ArcGIS Pro: Batch geoprocessing. The images below show the Feature Outline Masks running in batch mode.
Batch Feature Outline Masks
Batch mode
文章 ID: 000022737
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
