问题
在某些情况下,当在 ArcGIS Server Manager 中访问服务器日志时,日志会显示不一致的结果。 例如,对于某些过滤器,首次查询会显示正确的结果,而后续查询会显示错误或奇怪的结果。
ArcGIS Server Manager 中的日志文件已损坏,但在 ArcGIS Server Administrator Directory 中查看日志时,却无任何不一致之处。
执行清理操作。 清理操作将强制服务器清理日志,由此释放磁盘空间。
Warning: This operation is irreversible. Once invoked, this operation deletes all logs on every server machine on the site.
Note: It is recommended to create a backup of the ArcGIS Server site configuration before proceeding with the following steps. Refer to ArcGIS Server: Making a backup of your site for instructions.
https://<gisserver>.<domain.com>:6443/arcgis/admin
Note: Do not copy the old logs from the backup folder to the newly cleaned directory. If required, explore the old logs from the backup folder.
文章 ID: 000032770
获取来自 ArcGIS 专家的帮助
立即开始聊天
