问题
问题:ArcGIS Pro 遇到严重的应用程序错误而无法启动
描述
When starting ArcGIS Pro, the application fails and returns the following error:
Error:
ArcGIS Pro has encountered a serious application error and is unable to continue.
User-added image
原因
This is a generic error message that can be returned due to various causes, however when starting ArcGIS Pro, this error often occurs because the user.config file is corrupted.
解决方案或解决方法
Create a new .config file
To locate and delete the corrupted user.config file by following the steps below:
It may be necessary to enable viewing of hidden folders to view the AppData folder in Windows. For more information, refer to Microsoft: Show hidden files.
  1. Navigate to the following folder path:
C:\Users\<USERNAME>\AppData\Local\ESRI\ArcGISPro.exe_Url_usrdyax2a4fbxzcclmgcafuxifk3o351\1.4.0.0\
  1. Delete the user.config file.
  2. Start ArcGIS Pro.
Rename the ESRI folder
By renaming the ESRI folder to a name other than ESRI, a new ESRI folder is created with a new .config file when starting ArcGIS Pro.
  1. Navigate to the following path:
C:\Users\USERNAME\AppData\Local\
  1. Rename the ESRI folder (for example, to 'ESRI-old'.)
文章 ID: 000015754
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
